Hymer Nova - water tank
JTLT
JTLT Forum Participant Posts: 14 Participant
edited September 2013 in Caravans #1
We haven't used our 2005 Hymer Nova 435 yet - hopefully next week will be our first time. We're a little unsure how the water system works.
Inside next to the TV aerial point there is a switch just like one of the light switches that the previous owner labelled as "water pump".
Outside the van there is a filling point that looks like a car's petrol cap. There is a further panel which has a small black rocker switch, a metal push-fit connector and a small blue plastic female electrical connector. With the van was a length
of hose with a pump at one end and a cable with a blue male connector that matches the female connector on the van.
The confusing part is really the two switches together with warnings I've read elsewhere about the danger of damaging seals if the whole process isn't done correctly.
The manual is frankly useless and the dealer we bought it from wasn't much more helpful.
So please could someone tell me how I fill the onboard tank from an Aquaroll and then have the Aquaroll connected and ready to use as backup?
