| Hi can anyone help I'm trying to find a relay for this Sargent unit in the UK the relay is a Sun Hold RAS 1215, G0610SX, 12v 15A pcb mounted , 5 pin I believe it is latched type. |
A pdf file for relay is @ http://www.sunhold.com/upload/prd1/25-3.pdf, in the Sargent unit there are two pcb's the relay sits on the bottom one, there are three on this pcb but its |
| the one on the right I think its for the power, I have fitted a relay from RS 217-2876 Panasonic JSM1125 which works until I start the engine then it drops out cutting power to |
| dvd player, reversing camera & fridge, which is why I think it's latched type. |
| the faults I had was the fridge was not keeping very cool the fridge was on mains electric, the lights in the motor home where flickering, which leads me to believe the contacts in the |
| relay are dirty, the relay is all sealed so can not be cleaned. Sargent can do a service on unit for £80 which is find if there a lot wrong with it, but for a £1 to £3 relay is a lot. |
| All the relay suppliers I can find are in far off lands and web sits not in English. Thanks |
