Motorhome Fuel Consumption
cyberyacht
edited April 2016 in Motorhomes #1
How long is a piece of string?
When we eventually sell our apartment in Spain, we are thinking about switching to a slimline MH about 6M max 3500Kg. Can members with similar weight/size MH's give me an idea of average fuel consumption so that I can compile some data to work with? Thanks
in advance or 'march has grass ears' as they say out there. Wink
    edited April 2016 #2
  • Grumblewagon
    Grumblewagon Forum Participant Posts: 246 Participant
    edited April 2016 #3
    My old 'Wayfarer' with its petrol engine only gave about 25mpg, but my current Romahome R30  2.2 Diesel gives around 36 mpg.  This is probably a bit smaller than you're thinking about, but I would expect most modern compact vans to give in the low - mid
    30's.
  • JD6620
    JD6620 Forum Participant Posts: 202 Participant
    edited April 2016 #4
    Our previous motorhome was a 6m low line coachbuilt with a max weight of 3400kg.  Fuel consumption was between 28 - 32 mpg.  We now have a highline 7m 3750kg van and fuel consumption is 25 mpg.
  • brue
    edited April 2016 #5
    We average out 35 mpg, coachbuilt motorhome 3500 kg under 6m on a mercedes sprinter auto, 2.2 diesel.
  • EJB986
    edited April 2016 #6
    My 6m, 3500Kg coachbuilt has avaraged 30 MPG for the last 8 years based on speedo readings.....so would expect a true figure of about 28.
    It seems that PVCs can get up to 35.
    Over 6m and over 3500Kg  average 25ish!
  • PaulandKate
    PaulandKate Forum Participant Posts: 64 Participant
    edited April 2016 #7
    Peugoet boxer compass 200 coachbuilt 5.9 meters long 3 meters high
    2.0hdi engine remapped to110hp
    3000kg we are getting around 30-35 mpg
    Tinwheeler Forum Participant Trusted Posts: 24,398
    edited April 2016 #8
    The same as Brue except ours is 6.4m and we drive it hard so 25-30mph.
    Like all vehicles, CY, the mpg depends on numerous factors.
    See  http://www.caravanclub.co.uk/community/discussions/information,-technical-tips-advice/motorhomes/Lunar-Landstar-Motorhome/rt/1446165/
  • NET SUKE
    NET SUKE Forum Participant Posts: 3 Participant
    edited April 2016 #9
    We get around 33-35 mpg on our 6m Citroen Relay PVC (L3 H2) 130bhp,  based on 18 months ownership.
    DavidKlyne Club Member Posts: 14,881
    edited April 2016 #10
    We have averaged about 25 mpg in our Bailey 740 which is quite a bit bigger than the size you envisage. It depends what you currently tow with but 25mpg is a better than my previous towing economy although my towcar was an auto.
  • peegeenine
    edited April 2016 #11
    Type of body, I would think, as opposed to length has the most effect on consumption (assuming 3500kg). Big overcab designs aren't very aerodynamic and an A class is a bit like a brick. Width too will also play a part with Bailey offering some of the widest.
    Low profiles and PVCs will give the best results as will a small shoe size and whimpy leg muscles. My 2.3 130bhp Euro IV Fiat Ducato always returns in the high twenties with up to 32mpg achieved quite often. I usually run at around 2250RPM which is slightly
    quicker than HGVs. I have even achieved 27mpg towing a 900kg car behind. Figures quoted are from dashboard computer and I use cruise control at every opportunity, which is virtually all the time.
  • Apperley
    edited April 2016 #12
    We have a 2015 Bailey 745 (3500 kg) with 3500 miles on the clock, so still running in. Last journey of 350 miles I got 28.8 mpg. To be fair I travel at 63 miles per hour on motorways, so I guess I'm nt thrashing it.
  • Aspenshaw
    edited April 2016 #13
    Probably 28-30mpg.
    Coachbuilt with overcab will give you c27mpg, a low profile coachbuilt 28mpg, an A-class 29mpg, and a PVC [Panel Van Conversion] 31mpg. This assumes you would drive as carefully as a sensible caravanner tows. I would allow 2mpg either side for variations
    in your driving style.
    Individual journeys would give you a variety of fuel consumption depending on weather and route. I do 25- 27mpg west to east over the Pennines and 27-32mpg going the other way!
  • kenexton
    edited April 2016 #14
    CY,our 09 plate Renault Master 2.5 dci lwb high top  PVC ,3500kg with manual six speed box returns 33/34 mpg consistently on long runs at 2000rpm /65mph-this over years of ownership.An annual full service is £186 at our local independent garage(air filter,oil
    and filter and fuel filter included.) Hope this helps.
    edited April 2016 #15
    Thanks for all the input, folks. PVC's seem to be the least thirsty but I am wondering if this is due to some of them not being hi-tops. I currently get around 30mpg with 1350Kg van behind a 134BHP Kuga but this reverts to 40mpg once on site. With a MH I
    am not going to get that "rebate" upon arrival unless I do a lot more pedalling than I am used to. Another consideration for the evaluation matrix.
  • ScaniaMan69
    ScaniaMan69 Forum Participant Posts: 75 Participant
    edited April 2016 #16
    Too many things affect motorhome mpg - in my opinion, these are....
    1) Height - some are 3.5m high - these will burn a lot more fuel than a 2.85 low line
    2) Speed - chin up and foot down burns more than ambling along at 60
    3) Weather - a strong head wind can knock our mpg to the late teens.
    That said, the present van, having covered almost 10000 miles in nine months, has averaged 27 mpg, 5000kg six wheeler van, driven with respect.
    I do not feel that weight affects it. OK, a 5000kg van will likely burn more fuel than a 3500kg version, but whether our van is packed to the rafters or lightly loaded, it matters not, hence we always travel with full fresh water tanks.
    In my view, a low line, 3500 kg model, manual, six speed, driven with respect, aim for 30 mpg. On long motorway stretches, we can get 29 mpg on our lump.
    Russ
    peedee Forum Participant Trusted Posts: 10,161
    edited April 2016 #17
    It is nice to have a low fuel consumption figure but why buy a motorhome if you are worried about consumption? Other consideration might be the saving on road tax as compared to other vehicles and this can be used to off set some of the higher fuel consumption costs.
    edited April 2016 #18
    I wouldn't say I was worried but it is a factor to consider in evaluating the benefits or otherwise of changing from a caravan.
    edited April 2016 #19
    It is not a factor I would consider CY, there are much more important factors. Fuel consumption was not one I considered when moving from a caravan to a motorhome or for that matter,road tax . In most cases, unless you are buying a very big motorhome e.g
    an American RV, consumption is on a par with tugging.
