Bailey Ranger water pump problems
crannman
crannman Club Member Posts: 101
hi all we have a 2007 bailey ranger while away at weekend the waterpump started playing up very little water coming out of all taps red light on panel for pump flashing (doesnt stay red all the time sure it should ) the pump we put in aqua roll is new tested
it its ok a fellow caravaner said it could be the in line filter ? tried waggling pump and in the odd possition all is well so could it be a conection problem .work at moment stopping me having a good look at it but free weekend to sort it out .......any ideas
  • charlieboy2608
    charlieboy2608 Forum Participant Posts: 25 Participant
    edited April 2016 #2
    Hi there
    Had a similar issue on my bailey-ended up being the filters in each of the tap nozzles-just carefully unsure each tap end and you should find either/both plastic/mesh in line filters.Just blow them out and reinstall.
  • crannman
    edited April 2016 #3
    thanks charlieboy will have a look at that
  • crannman
    edited April 2016 #4
    booth filters are clear im right in saying the red light should be on when the pump is on
  • davehurst
    davehurst Forum Participant Posts: 48 Participant
    edited April 2016 #5
    i had allsorts of problems on our South coast trip last year. One minute it was fine the next it just wouldnt work. This went on for a few weeks till the pump eventually gave up the ghost. I bought a new one and everything has been good ever since. BTW i
    have one on ebay if you need it. Wink
    I ended up with 2 new ones.
    Don't ask, it's a long story.
  • davehurst
    edited April 2016 #6
    Also, check the presure valve.
  • crannman
    edited April 2016 #7
    Write your comments here...thanks davehurst will check presure valve
  • crannman
    edited April 2016 #8
    problem solved re set the pressure switch Laughing
  • commeyras
    edited April 2016 #9
    Was about to suggest check pressure valve glad it solved the problem.  I carry a spare set of 'O' rings which can give a similar sympton if faulty.
  • crannman
    edited April 2016 #10
    think when we had van serviced he must have touched it ? never had a problem with it before
