Water Pump Problem
commeyras
Club Member Posts: 1,853
The latest CC Mag on page 14 'Expert Advice on tap' answers a question about a water pump keeping turning on every few minutes and suggests that the problem could be air in the system. I had similar symptons with my pump and solution turned out to be replace the
O rings. So if you have these symptoms cause of ar getting into system could be O rings.
