Truma ultra heat
ALANkW
ALANkW Forum Participant Posts: 70 Participant
edited April 2014 in Caravans #1
We are having a problem with it assume the thermostat. When on the stat eventually cuts out and takes at least an hour to kick back in even on maximum. The thermostat is fitted on the wall above where the heater is fitted into a cabinet I can only assume
the heat is building up in the cabinet as if I take out the cutlery draw above it doesn't appear to cut out.  The van is not yet a year old but I can't see it being covered by warranty as to me its a design fault. Anyone have any experience of this issue
