How much gas will I need?
Andrew and Sarah
Andrew and Sarah Forum Participant Posts: 3 Participant
Hi, we are new members and complete novices, hiring a motorhome for the first time this summer to spend approximately 18 days touring in Europe, staying at CC sites at each stop. The Autotrail Cheyenne 660 will be equipped with two full gas canisters by
our very friendly hirer. Will that be ample/OK/not enough for two adults? We do a fair bit of cooking and both like a shower at least once a day, but will make use f the electric hook up at each CC site. If insufficent, whats's the best solution: are we better
to take another canister, buy a conversion valve for European usage or any other solution we don't know about?! Thanks in advance for helping two eager novices! Andrew and Sarah
  • IanBHawkes
    IanBHawkes Forum Participant Posts: 212 Participant
    edited May 2016 #2
    If, as you say you are going to use the site electricity 2 cylinders should be more than ample. You should be able to use the hot water on electric and the fridge. So, the only thing to use gas will be the cooker and if you used a barbeque that might use
    some extra. But, you should be okay.
    I am going away to germany for 3 weeks and I have about 7kg of gas and I reckon that will be enough.
    Enjoy you time abroad.
  • AlanAlde53
    AlanAlde53 Forum Participant Posts: 27 Participant
    edited May 2016 #3
    Hello Andrew and Sarah
    We are currently in France for 9 weeks and are only carrying 6kg of gas and we expect to take most of it home. If you are always on electric it is surprising how little you use even with the oven being used most evenings. I would expect your consumption to be less than 2kg. If however you stay where there is no electric then others will be along soon to advise
  • Andrew and Sarah
    edited May 2016 #4
    Thanks Ian and Alan, really helpful and kind of you both to reply so quickly.Sounds like we will be fine! Well, at least on the gas front anyway! Happy
    edited May 2016 #5
    It's quite true 'Alan' that using EHU whenever possible makes gas last a long time. A bottle lasts us for years.
    DavidKlyne Club Member Posts: 14,606
    edited May 2016 #6
    In Europe you won't tend to get the high ampage that you get in the UK, except perhaps in Germany. This means that you might have to supplement electrical usage with gas. However for 18 days I expect you would have more than enough gas to cope and will probably
    return home with at least one full cylinder.
    edited May 2016 #7
  • thebroons
    thebroons Forum Participant Posts: 165 Participant
    edited May 2016 #8
    We recently spent 5 days off grid in our m/h and luckily had nice weather so only used the gas for cooking , fridge and hot water. We only used 5 litres of gas so you will have plenty in reserve.
  • Tirril
    edited May 2016 #9
    We used a site for 2 weeks each Aug for many years without an EHU. We consistently found that a 6kg of Calor last exactly 2 weeks. The main consumer was the fridge with a smaller amount for cooking and we heated the water when required rather than leaving it permanently on. As you are using a motor home which will run the fridge when travelling plus EHUs during the evenings/nights I would be surprised if you used even one cylinder assuming it is the usual 6kg.
    edited May 2016 #10
  • jennyc
    edited May 2016 #11
    I can't imagine that you will run out of gas, especially since there are so many summer salads and 'picking' foods like good cheese, fresh bread dipped in olive oil, continental sausages etc to eat.  BUT, for a 100% feeling of security you might like to
    consider our own solution which is a Camping Gaz bottle to supplement your bigger and cheaper to fill UK bottle. Buy an adaptor to fit the Gaz, converting it to your UK pigtail, but use your UK gas first. If you do run out then you have a refillable backup.
    Our BBQ is fitted with a quick release gas connector, and we have a matching regulator/ adapt or for Gaz, so the lightweight Gaz bottle will serve for days out, away from the van if we chose, either in the UK or abroad.
  • Andrew and Sarah
    edited May 2016 #12
    Thanks to eveyone for all these helpful replies; much appreciated. Andrew and Sarah
    edited May 2016 #13
    peedee Club Member Posts: 9,996
    edited May 2016 #14
    A good yardstick in summer months when not on EHU is 0.5KGms per day.
