Help! Where can I fill up my Safefill gas canister
1Tracey1
We are staying at Stokesly (near Darlington/Middlesbrough). Does anyone know where I can fill up my safefill gas canister? Thank you
  • MJ730
    MJ730 Forum Participant Posts: 184 Participant
    edited March 2016 #2
    According to safefills website Stokesley Motors Limited
    1 Manor Cl, Stokesley, Middlesbrough, Cleveland TS9 5AG, United Kingdom 01642710566. are listed as a refill centre.Good luck hope they work.
    Mike
  • 1Tracey1
    edited March 2016 #3
    Hello.  Thank you very much for your message.  I lost my signal so was unable to see your post while I was away.  However, we did find Stokesley Motors (about half a mile from our site) and filled up our bottle.  Thanks again :-)
  • AndyNYorks
    AndyNYorks Forum Participant Posts: 144 Participant
    edited May 2018 #4
    Can anyone confirm that I can fill my Safefill bottle at Ullswater Garage in Penrith. They are listed on the Safefill site but occasionally it seems to be out of date?
  • DaveCyn
    DaveCyn Club Member Posts: 398
    edited May 2018 #5
    Main details now seem to be on MYLPG.EU
    The garage is listed as selling LPG but no mention of allowing Safefill.
    Suggest you give them a call & check. If yes you could advise the website so that it can be added.
    edited May 2018 #6
    edited May 2018 #7
    I don't know what Shell's official policy is but I have just topped up at Titchfield, St Margaret's roundabout. PO14 4BB. Before arriving, I disconnect my hose and turn the bottle to face outwards from the locker. I just pull up at the pump, open the locker and hook up. Whether they would be twitchy about unloading a cylinder from a car boot to refill, I couldn't say.
  • Merve
    edited June 2018 #8
    Filled my Safefills there last year. No problem.
  • AndyNYorks
    edited June 2018 #9
    Thanks Merve, we visit the area regularly and its useful to know where I can fill my cylinder.
  • Merve
    edited June 2018 #10
    Just made our way down to Tigerfish’s territory- Bristol - to visit my daughter and to take my two Bristol based grandsons camping and fishing for a couple of nights on the Chesil. Before leaving, I remembered that my 20lt Safefill was empty and my small 5lt one needed topping up so I loaded them and set off for Bristol with the satnav going to Andy’s Gas first. At this point I appreciate that I am lucky to have a daughter based in the same city as probably the most competitive LPG supplier around! Known on this forum for keen prices I arrived at Andy’s Gas and produced my cylinders. 49p a litre! 10p per litre off the advertised price for Safefill top up! 22.8 litres was dispensed all together. The bill- £11.17 So, working on 1.96lts per kilo that made 11.63 kilos. Working on Calors £24 per 6kg swap cylinder- that’s £4 a kilo. So,  4 x 11.63 = £46.53!! That is what I would have had to have paid Mr Calor for the same amount of gas!! Less than a quarter of the price! Congratulations to Andy’s Gas for leading the way with competitive LPG prices. That is why I would have bought a Safefill even if my useage was far less- Another 5+ nights on a non EHU site paid for by savings in gas cost. I am quite envious of caravanners who live in and around Bristol- I wish we had someone like Andy’s Gas round our way!! 🤣🤣🤣
  • Merve
    edited June 2018 #11
    Hi Andy. Dead easy from what I remember- they leave it to you to fill and you just pop into the office to pay.
    edited June 2018 #12
    well I tried the "mylpg.eu and gave me a place in cleveleys so headed up the road to enquire, could not find and garage next door said not been there for over 30 years.
    edited June 2018 #13
  • Merve
    edited June 2018 #14
    Yes, a good point DD. We can all help one another if we take the trouble to confirm a site is present and fills Safefill.
  • MillieMaster
    MillieMaster Forum Participant Posts: 41 Participant
    edited June 2018 #15
    I built and own a self built very luxurious panel van campervan into which I installed a Safefill cylinder.
    Because I was going to be touring France where I know it is illegal to fill up stand alone gas cylinders and because of the problems I had experienced at times refilling in the UK I decided to try to convert install a external wall mounted filling point.
    Unfortunately these excellent cylinders don't have 2 entries into the cylinder and they have no plans to change the design, so I made contact with Gasit, who, following discussions, supplied me with a wall mounted filling point, a length of high pressure hose, a pig-tail connection to fit the tank and an in line on/off lever valve.
    Following installation, all I now need to do when I need to refill the tank, wherever I am in the UK or Europe, all I do is swap the normal gas take off hose from the top of the tank and attach the pig-tail ended hose from the external filling point and then open the on/off valve.
    I then drive to the filling station and connect the filling hose to the external filling point and that's it, one safely refilled tank and no questions asked!  I then proceed to wherever, open the gas locker, turn off the lever valve, disconnect the pig-tail and reconnect the normal hose.  Job done.
    This set up has now been working perfectly for several years without a hitch and without a single question being asked.
  • DSB
    DSB Club Member, Member Moderator Posts: 6,273
    edited June 2018 #16
    Well done MM, not only in finding a solution, but for completing an adventurous task.  Far beyond what I can do.
    edited June 2018 #17
    done.wink
  • MillieMaster
    edited June 2018 #18
    Honestly David the conversion I made wasn't at all difficult to do.
    The most difficult bit was the planning and design and that now has been done for anyone else to do exactly the same, then of course cutting a hole in the body might be utterly frightening to some, but when you pluck up courage and measure and mark the cut aperture several times over that is easy as well.
    As I wrote Gasit supplied the parts I needed, I don't know if they would, but if anyone wanting to make this simple mod didn't want to do it themselves, possibly Gasit would do it for them?
    Phil
  • Merve
    edited June 2018 #19
    Well done Phil. Sounds like you found the solution that suits you and that’s what it’s all about. Another guy not getting ripped off renting cylinders!!
  • shedload
    shedload Forum Participant Posts: 3 Participant
    edited June 2018 #20
    Phil, I recently purchased a 10 kg Safefill cylinder and very intertested in your external wall mounted filling point. Can you clarify please - is the filling point or the line on/off lever valve one way only, otherwise with the LPG gun released, what's stopping the gas coming out?
    When filling the cylinder direct, the cylinder manual stop tap is opened and closed to allow for gas flow / no gas flow I believe.
    I suspect I'm missing something obvious but can't see it at present.
    PS - I haven't filled the cylinder yet, but will be shortly for summer trip to France.
  • Merve
    edited July 2018 #21
    Tweet from Morrison’s!! Their sites are now accepting Safefill cylinders! Congratulations to Safefill for the dogged determination they have shown. I have always believed this would happen and now it’s here. Other large businesses will now, I’m sure, come on board. Well done Safefill and congratulations to Morrison’s who actually ‘get it’
