Truma Heater Problem
abruzzopietro
abruzzopietro Forum Participant Posts: 1 Participant
edited October 2013 in Caravans #1
The Truma Ultraheat 3002(P) in our caravan has ceased to provide any heat on either the 1000w or 500w settings (it still works fine on the 2000w setting).  I believe that there is only one heating element and therefore suspect that the controller/thermostat
is at fault.  I have however seen references to relays and am not sure whether these could be the problem - or where they are located.  I would be grateful for any advice as to how to test for (and resolve) the problem.
