Help water pump problem on Compass Corona 475
4 Marshalls
Hello. My caravans water pump is running constantly and can only be turned off by switching off the main pump switch. I've been told theirs a micro switch in the tap that senses when tap is being used is this correct? Is it easy to fix and could i do it
myself? I would be gratefull of any help. Thanks.
