Help with Pick-up Bed Cross Bars for a Roof Tent
TitanL200
TitanL200 Forum Participant Posts: 1 Participant
Hello. I need some help from you wonderful people.
I have a 2018 Mitsubishi L200, and I'm wanting to install a roof tent over the truck pick-up bed rather than the roof.
I need some cross bars.
However, I have a Titan Roller Shutter installed. It has T-Tracks on either side. (138cm wide, 140cm length).
The advice im getting from certain suppliers isn't consistent so im reaching out to see if any one has done this. My main concern is the load weigh limit. Factoring tent weight and people you are looking at 250 to 280kg.
The bars ive looked at so far all say load capacity is only 100kg.
If any has this setup, can you share what you are using?
Appreciated, Steve.
  • Rowena
    Rowena Administrator, Club Member, Staff Posts: 647 admin
    Hi @TitanL200 and welcome to the roof tent group! Did you mange to get this sorted? If you have nay photos to share I can send on for advice or if you've any advice now to share with others on the set up that would be great! ☺️
